Tincho »
https://forums.nicoclub.com/tincho-u1962.html
Thu Jan 30, 2003 5:57 pm
Hi guys,
I've already posted a few threads concerning my annoying clutch. I got it replace about a year ago and I've had a few problems with it. It didn't have much grip, my car would shake when I'd drop the clutch going up hills, the pedal wouldn't return as usual on cold days (I'm from Montreal, so temperatures of the order of -68F are quite normal here) and the pedal was way too soft for my taste. However, the action on the clutch was at the top of the pedal (the linkage would move without having to press to much on the pedal). Last week, the pedal started feeling even softer than before, but the friction point was still at the same location. Two days ago, the friction point moved to the bottom of the pedal, leaving a lot of free pedal before any action. Furthemore, the pedal is not returning as usual. How could this be explained? Should I drive my car? Is there any way of adjusting the clutch back to its position? Any help is highly appreciated. Thanks in advance!
Martin
