cluster problems
sr20detRcr1
Car: 92 Nissan 240SX
Car is a 92 coupe w/ s13 sr
well to start it off, we just swapped the engine into my s13 and when we hooked up the battery all the dummy lights(gas,seatbelt,brake, etc) would stay on, as well as my SAFC with out the key being in the ignition.
so that being i took the engine bay harness from my old car that had the SR originally in it and put that into the car and the problem went away.
then i noticed not everything on the cluster was working, only the Clock/Back Lights/ and the gas gauge some what and the battery light is on but very very dim, but the Tach/Speedo/Temp/Dummy lights do NOT work
i have tried different clusters, different cluster harnesses, checked out the fuses, nothing.
thanks
