Best bet is to use the factory service manual. Here's a link! There's also a couple videos on YouTube if you're not used to the FSM's layout, it can be frustrating.jjf123 wrote:Hi, Im gonna put in a s13 cluster i got from the junkyard. but the mileage reads 270XXX, and my read 125XXX. I want to roll back the odometer on the new cluster. It looks easy to take off, but seems fragile. I want to know if theres an actual method to removing it. Thanks
Klot wrote:Best bet is to use the factory service manual. Here's a link! There's also a couple videos on YouTube if you're not used to the FSM's layout, it can be frustrating.jjf123 wrote:Hi, Im gonna put in a s13 cluster i got from the junkyard. but the mileage reads 270XXX, and my read 125XXX. I want to roll back the odometer on the new cluster. It looks easy to take off, but seems fragile. I want to know if theres an actual method to removing it. Thanks
240sx-fsm-full-service-manuals-s13-s14- ... 11075.html
