Cluster lights S14
DMan II-40
Car: 1995 240SX SE
I'm about to order some LED bulb replacements for my gauge cluster (getting blue). I read that there is 3 bulbs you need to replace. But my questing is if the clock has its own bulb, because my clock bulb is burnt out anyway. Would that make 4 bulbs? If so what is the bulb number for the clock.
sebazztard
Car: 1992 Nissan 240sx rb25det project. 2000 Honda Accord LX DD. 1992 Nissan 300zx NA.
blue doesnt look good behind the white face. i tried this and went back to white led. it looks terrible at night and its extremly hard to read the gauges. if you had a base model cluster i think it would work, but behind white, . i forget the numbers man, i just went through all this not even a few months ago. 194 for the lights and 74 or 68 for the clock?? something like that.
Modified by sebazztard at 11:49 PM 9/27/2008
sebazztard
and yes, its actually 3 main 194s, and 1 smaller size for the clock.
kamikazestorm420
yep 3 194s
DMan II-40
Car: 1995 240SX SE
Ok cool. I just put an order for over $50 in different LED lights. I will make a topic when I'm done. I'm replacing the Cluster, Overhead dome, trunk, License plate, and map lights. Should be something fun to keep me occupied.
sebazztard
done the same with white. pack of 10 keeps you busy lol.
sldewyz
Car: 97' Danger Ranger
jesus...how many led's did you get? 50$...i got 5 for my s13 cluster for i think 11 dollars shipped? check out superbrightled.com
DMan II-40
Car: 1995 240SX SE
Yea i got all my stuff from superbrightleds.com But im not only doing the cluster. Im basically redoing all the lighting in the cabin (including trunk) and my license plate lights. I think I bought a total of 9 LEDs. Two of them were kinda expensive, like $6.00 and the other was $14.00 I believe.
stephen240
Car: 95 240SX
Hey man which bulbs did you use in your s13?
like 3 led? 4? 5? V shaped ones?
sldewyz
stephen240 wrote:Hey man which bulbs did you use in your s13?
http://www.superbrightleds.com...e.cgi?
WLED-x-x LED bulb about an inch down the page.
product=CAR&keywords=&cart_id=3077012.4676&next=50 i ordered 5 but you only need 4. i used the other one for my battery light as an extra.
