Cluster Issues. Have searched need help.
Busted240749
Car: 1993 240sx
I have been searching for an answer for a while but no one has the same issue so i finally decided to just ask for help.
First a little back ground on the car. It is a 1993 240 coupe. I bought the car with a blown motor so i put a Ka24de out of an s14 into it. My lower engine harness was a rats nest so i pieced it back together the best i could. the car runs with a bobble when i hit the gas.
My problem is in my Gauge Cluster. The only thing that works is the red lights on the bottom right hand side, seat belt, brake, etc.I have no tach, and no temp and no back illumination. I think my gas gauge is working. Any help would be great.
Klits562
Car: white s13 coupe
its probably the wireing look for the wiring diagram for all of that and double check it all
Busted240749
Car: 1993 240sx
thanks for the suggestion. any idea where i should start though
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
if that harness is as bad as you're making it sound, I'd be hitting up a junkyard and asking what they'd charge for you to pull one yourself... Then just change your entire harness... (It's sure to cause more issues later...)
Busted240749
Car: 1993 240sx
I am definitely going to be getting a different lower harness sometime soon but I didnt think that would cause te problems I am currently having. My upper engine harness looks good.
