sleeper180 »
https://forums.nicoclub.com/sleeper180-u155120.html
Fri Mar 05, 2010 8:43 pm
accuatly since u said u had a sohc ka in it an u swaped a sr20 that has a dohc i think u need to change ur tach in the rpm and should work fine then, im not totally sure but i know if you have a sohc cluster and u try to use it for a dohc your going to need to change the needle in the rpm or so i heard before
