Cluster Gauge project, change orange ring to blue ring.
General discussion area for the L32-chassis Altima
mcsniper703
Car: 2009 Altima Base Black
Enjoy!
el_blacky06
Car: 2007 Nissan Altima Sedan 2.5s 6MT
nice color dude! how did you acomplish the ring color?
mcsniper703
el_blacky06 wrote:nice color dude! how did you acomplish the ring color?
More information can be found here.
removing-the-orange-strip-from-stock-da ... 78220.html
el_blacky06
looks like all the pictures are cut in half
mcsniper703
el_blacky06 wrote:looks like all the pictures are cut in half
it not that hard really. first, be sure to raise your steering wheel high. you would need to pop off the steering panel below the steering wheels start on the right side, pull it to pop panel away to open.
left side of steering wheel, pull the panel but dont do it hard because it kinda stay there but there one tab that need to be pull to pop open. when you're done, then the cluster gauge trim, pull it starting the top, once u take that out, there be 2 screw that holding the gauge in places a top of gauge. unscrew it boths. then pull out slowly the gauge cluster. the plastic gauge cover, there tab around it that locked in, lift the tabs slowly and dont do it too hard. once u removed the plastic cluster cover, remove the plastic gauge trim, dont break needles. then ur project start from there. good luck. let me know if u need more helps.
Return to “4th Generation Altima Sedan (2007-2012)”
