Cluster doesn't work
TwoFortyCoupe
Car: 1991 240sx w/S14 KA-T
T3/T4 .63 AR 50 Trim
Audi R8 Ibis White Paint
2007 Acura Tsx
Hey guys,
So I was driving down the road doing like 45 Then look down again and nothing works, no needles moving no lights nothing. I replaced the 10 amp defuse which was blown and I started it up no lights still. It blew that new 10 amp. Please help. Thanks,
TwoFortyCoupe
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Unplug your dimmer switch and then replace the fuse again and see if it pops.
biggie
If something shorted and you get your gauges back and still no lights, then the TCU may have blown.
TwoFortyCoupe
2007 Acura Tsx
I thought it could be the TCU but my gauges went to.
biggie
Could be TCU as well as other things.
compactfean
daily
Tcu as in transmission control unit?
biggie
compactfean wrote:Tcu as in transmission control unit?
Timing control unit, white box in the driver's side kick panel. When it blows the lights don't work in the cluster. Usually happens when installing a radio and crossing some wires though.
compactfean
daily
Damn! This happened to me a long time ago and I ended up bypassing what ever was the issue and running a separate ground and power to the gauge lighting. Good too know!
TwoFortyCoupe
2007 Acura Tsx
Ok update on what happened. I just wired the boost gauge and the AEM wideband from the cruise control to try and get less stress of the cluster, and that worked the lights went on and everthing was working .....for about a minute and then blew the fuse. I put a 15 amp in the 10 amp socket because maybe strong amp could work. It didn't. So yet another day with no cluster working but my external gauges (wideband etc) all work. Good news though MY HUD WORKS. I bought the car and the guy said its fried but it was just disconnected plugged it in and it worked. Well when cluster works it works. Should I just do what you did compactfean and just run separate ground wires? Or will my tach and stuff still not work?
compactfean
daily
Here is all the info you will need. is it just the lights or the gauges?
how-to-fix-s13-wiring-for-gauge-cluster ... 26276.html
Armstec_S13
Car: S13 Coupe
I'm having somewhat of an issue with my gauges, it only does this in cold weather, i have an 89 coupe 5spd, it has the HUD, anyways, when I go to start it on very cold days, my gauge cluster lights and HUD won't light up, the tach, temp, gas gauge still work but the HUD will not turn on and the gauge lights won't either, then after the car warms up the the Dash lights and HUD come on and work as they should, anyone have this type of issue?
biggie
About everyone with HUD has had that issue. The board for the HUD goes out. Can replace or try to fix yourself. If you search for HUD fix you should find a few threads.
TwoFortyCoupe
2007 Acura Tsx
Ok so when I swapped out the whole dash board, the original digital cluster started working except the HUD doesn't work and the speedo doesn't work either. :werd:
biggie
Speedo and HUD are one and the same. If the Speedo doesn't work the HUD can't work. Mostly likely the board has went bad and needs to be replaced (or fixed, search for HUD fix).
TwoFortyCoupe
2007 Acura Tsx
Thanks biggie never thought of that and could the speedo like about to die cause a shorting in the fuse?
biggie
Possible, but I doubt it, probably something wiring related that's shorting the fuse, or maybe the fuse is too small and there should be a higher fuse in that spot.
TwoFortyCoupe
2007 Acura Tsx
Ok hit a bump and the whole cluster went again :mad: . Im stumped, I took apart the whole dash and thought I fixed it but apparently not.
compactfean
daily
Id say its hard wire time.
TwoFortyCoupe
2007 Acura Tsx
How would I hard wire it? compactfean can you pm me
