SR20DET.240 »
https://forums.nicoclub.com/sr20det-240-u74963.html
Fri Sep 21, 2007 1:42 pm
Ok guys, I now own an SR20DET swapped 89 240 but I have a few problems with it. I knew that the gauges didnt work but I assumed that since the previous owner didnt swap out the cluster with one from a DE motor that that was the problem, but I was wrong I picked up what I can only assume is a can only assume is a Canadian cluster since it has both KPH and MPH on it from a 92 DE. That has been installed and still the speedo and tach dont work.
So I started looking around at the wiring today and found that the reverse lights are wired to a harness that was just laying in the fender well that has four plugs comming off of it, my guess is that he just wired it to whatever he had laying around, so my first question is where do the reverse lights wire into the harness. I have found a few posts with wire colors but I am not sure that the person that did this followed the normal swap color guidelines so I would like to know if anyone knows where to wire them in directly asside from using a toggle switch.
Second, the speedo and tach dont work so I was thinking of wiring the speedo directly to the sensor on the harness but all I see in the other posts is that it runs to yellow/green stripe. This may sound stupid but the sensor has two wires, what does the othe wire run to ?
Last, the tach doesnt work either so I was thinking of wiring it directly to the motor but I dont know what wire combos are used, I was told that it connects to the crank angle sensor but I dont know what wires I should be hooking up since the only wire I know is the yellow/red stripe, but I dont know what wire that would correspond to on the motor.
If you guys have other options let me know, going directly to the wiring to the ECU is going to be a pain because they didnt leave it in the sheath, it is just a bundle of wires with butt connectors splicing them
Any help would be greatly appreciated, cant get this car to pass inspection until I get this stuff fixed.
Modified by SR20DET.240 at 5:00 PM 9/21/2007
