Clunky Suspension Reloaded
Mikey240sx
cory2081 wrote:ok, I checked mine. Driver's side was a little loose. They are both tight now and I still get that noise. Sounds like it's mostly from the passenger side. Any other suggestions??
I noticed the posting stopped hereI am trying to figure out what it is and you havethe exact same symptoms my car hasI was wondering if you ever fixed itand how? Or if anyone else knows about theclunky noise and how did they fix it?
NISTECH
it would help if you linked the thread that came from
Mikey240sx
NISTECH wrote:it would help if you linked the thread that came from
http://www.nissaninfiniticlub....Clunk
NISTECH
check your wheel bearings make sure they are both tight [do not over tighten them, finger tight then about a quarter turn] Check your tension rods as others had replaced in that thread, check the strut nuts up top. check you sway bars brakets and links, check your ball joints, and check your subframe mount bolts. One of those is your likely problem. You could also check your motor mounts by power braking the car and giving it a little gas the engine should not jolt when doing this it should only lean to one side the return when leting off the throttle ,not bounce back hard.
cory2081
Car: '07 Nissan 350Z
It's my strut mounts man. They're bad. I have some new ones on the way :)
Mikey240sx
cory2081 wrote:It's my strut mounts man. They're bad. I have some new ones on the way :)
Thanks thats what the Mechanic said, but I dont trustmost mechanics. So I decided to ask you 240 Nuts aboutthis stuff. What kind did you get? How much did it cost?
Oh by the way thanks for the help everyone.Even though I am completely car illiterate, meaningI have no idead where my struts are **turns around for kick in the *****But I am reading your guys stuff and learning.
cory2081
After searching for aftermarket pillowball mounts and finding them to be pricey and that most dont work with struts, I just ordered factory mounts from EverythingNissan.com, WAY cheaper than what my local dealer wanted!! I got them at just over $100 for both shipped. The local dealer wanted $80 each!!!
