Clunking
captluv
Car: 2001 Nissan Pathfinder
Hey all,
There's a clunking noise coming from my right front wheel area. It happens when I go over a pothole or any kind of moderate bump. It sounds like something is loose somewhere and gets bumped around a bit when I hit uneven road. What's the most likely cause of this; broken/worn shock or spring? That's just my first guess, I mean it's gotta be suspension related because of when it happens.
any help is appreciated. Thanks in advance.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Broken strut, worn out strut mount, discharged strut, it could even be loose lugnuts.
captluv
Did the bounce test on the shocks and they're all ok, in fact the car still rides smooth with no other problems except that sound. Could it be a worn out bushing? If so, which bushing is most likely to go on a strut assembly? Control arm?
MaximA32
my guess would be bad strut mounts. could also be a broken stabilizer link as well.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I have a similar problem on my 96 I30. It's a slight rattle/clunk when I go over bumps or go from forward to reverse. My lower control arm bushings are shot per the tire shop, so I think that might have something to do with it. I know it's definately affecting my alignment. It won't stay straight for more than a month.
Anyone know where to buy the bushings? Some people say you can only buy the whole are, but I've seen bushings online and at Autozone. Only problem with the Autozone bushings is that they are only made for the Max?
maxhopper
Car: 02 Maxima SE 6spd
You can get energy suspension bushings here. http://www.suspension.com/nissancars.htm
I would also recommend replacing the sway bar and end link bushings. They will tighten up the handling on the front end considerably.
captluv
Thanks for all the help guys. I took it to a suspension mechanic and it was a broken strut mount, so I got that fixed. But he also told me that it was time to do the shocks and lower bushings as well, so I plan to have that done soon (and yes, I will have the sway bar bushings done as well. My steering is a bit loose).
Staindfan03
Car: 1996 Infiniti I30
Check your front sway bar bushings and links. That is really common on most cars.
