clunking sound when turning, help?
Seanzyyy
Car: 1990 240sx se coupe
well after having a bit of fun with the car this past weekend,
i've noticed a strange, semi-rough clunking sound coming from what feels like the rear right.
i have a welded diff so im used to the occasional chirping when turning at slow speeds,
but when i turn right, it's a loud clunking sound that i can hear and feel.
soooo...
turning left it sounds like chirpchirpchirpchirpchirp...
turning right it sounds like clunk...clunk...clunk...clunk.
sorry for the lame sound effects :cool:
anyone have any ideas of what could be the cause?
thanks guys
btw, the car drives fine and everything, just turning right is rough,
the car "jolts" to the left slightly every "clunk"
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
My welded diff was making quite the racket for the past couple of weeks. Same sound you're describing. Pull the diff and make sure everything is torqued down and that it has enough fluid. Reason why I recommend doing so is because this happened to me the other day.
Most of the time it's the axles making the noises, as well. But it never hurts to check.
Klits562
Car: white s13 coupe
check everything in the rear end make sure your struts are fine and nothings leaking or broken on the axels.
also check the studs on top of the struts to make sure they havent sheared off it happened to me and turning hard in one direction would make some weird noises n feelings
Seanzyyy
ok, thanks guys,
will check today
poshatch
Car: p.o.s. 1990 240sx hatch
OMFG! THATS INTENSE :ohno:
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
ILoveMyRHS13 wrote: Image
:crazy: Yikes
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Needless to say? drop the diff and open it up and look at whats going on.
Have a friend help you put it back in. Alone is not the best idea.
GarageFyzo
Car: S14
Hey seanzyyy did u figure out the problem? I could use some help because I have the same problem, only difference with me is that a have a 2 way lsd and the noise is coming from the left side
