clunking sound from the rear what is it?
trigger94587
Car: 90' 240sx Coupe
first of all its a 90 240sx and i can hear a clunking sound from rear driver side but not much in passenger side. I just install a alluminum subframe collars to solve the problem but not its still there . I dont know where it came from and i have no idea what is it can anyone please help me? because the clunking sound is so annoying and i cant stand it anymore... I need ur help guys Thanks a lot!
steve s14
check the diff mounts and the driveshaft center support bearing. it also could be the halfshafts or possibly the diff itself.
trigger94587
where can i find it and how can i check this if its bad or if its causing the sound? im so noob in this things sorry...
steve s14
the center support bearing usually causes vibrations under acceleration and deceleration but it's worth checking.as for the clunking, you can lift the rear wheels off of the ground and place jackstands under the car to keep it safe and secure.then pull the e-brake and with the car in gear, hit the gas and let off quickly but lightly to load the driveline and get the clunking noise to happen.while one person is doing that, you or another person crawl underneath the car and see if you can find where it's coming from.look for parts that move excessively, and be careful not to put your hands or any other part of your body near moving parts.if all else fails, take it to a shop and have it looked at.
trigger94587
thanks! ill try what u said
trigger94587
BTW!! i can only hear it on rough roads and bumps but not much on straight roads...???
Musthavego
Car: 1996 Nissan 240SX
My '96 does the same... it feels like I have the slighest bit of play in the drivetrain. Any chance it's the u-joints or should I focus on the differential and differential mounts? Thanks
steve s14
on your car, you probably need to replace the subframe bushings or install the bushing eliminator rings.that's the most common problem.
steve s14
trigger94587 wrote:BTW!! i can only hear it on rough roads and bumps but not much on straight roads...???
if you are hearing it mostly on bumpy roads, it could be something that is unrelated to the driveline.if you have an aftermarket exhaust system, it might be banging on something under the car.i had to cut the tow hook off of an s13 because it was really close to hitting the muffler tip after i installed a megan 3" exhaust.
Musthavego
Thanks, I appreciate the help. Do you know who carries the bushing eliminator rings?
trigger94587
Yes i have a aftermarket exhaust system and it was hitting on my bumper so i zip tie it so it wont move even a lil bit but its still causing the sound... do u think it has something to do with my rear shock?
Bosrudorfer
Car: S14
shocks maybe?
trigger94587
how can i check if my shock is bad? or i have to replace it?
trigger94587
By the way I have a Tanabe Sustec Pro Coilover... Thanks Again!
steve s14
worn struts can make clunking noises when driving on bumpy roads.on coilovers with pillow ball mounts, the mounts can make noises when the pillow ball is worn out.
180fan
Car: 89 fastback
Check your motor/transmission mounts. Diff mounts if you've an s14 or z32, the driveshaft support bearing or worn ring gear.
trigger94587
steve s14 wrote:worn struts can make clunking noises when driving on bumpy roads.on coilovers with pillow ball mounts, the mounts can make noises when the pillow ball is worn out.
Thanks! ill try to check it out ill post again for follow up report...
trigger94587
180fan wrote:Check your motor/transmission mounts. Diff mounts if you've an s14 or z32, the driveshaft support bearing or worn ring gear.
Motor and transmission mount? i can just hear it on the rear driver side though... and i have a S13 Thanks for the reply!
McRussellPants
Car: 92 240SX
My car Clunks baaaaadddd.
Its getting worse, its obviously in the drivetrian somewhere since it only happens with the clutch in and making tight corners with a welded diff.
also sometimes with the clutch in going down Reaaallly bumpy roads.
now its starting to feel like theres an imbalance in the driveline somewhere.
IT ALL ADDS UP.
