Clunking noise when braking
blabla
I had a clunking noise while turning or braking for a while, then it disapeared. And now it is back...
Happens when I brake - release the brakes and then hit them again - this way the problem happens every time - otherwise it will happen randomly when I brake.
Seems to be caused by the wieght transfer to the front.
Wich I thought were involving my Tension Rods - but I already have changed them for Adjustable Tension rods - Also if that can help I have some tanabe ss coilovers and stock upper mount.
Anybody knows where that noise could come from ?
What other bushing do I have to replace
silpena
Car: Nis1993 san 240sx super hicas(wrecked)
soon to come to s-chasis
dudei have the same problom on my car. i would to know also.
sp33dg33k
Car: 1997 240sx SE
I have the same problem and I think it's the coilover spring. It could be my brakes too because I just installed new calipers and I can hear the noise from left and/or right.
onosqv
Car: '92 240sx Vert
are you sure you tightened the coilover lock nuts enough? I had that problem at low speed turning/reversing and found out my lock nuts loosened themselves..
sp33dg33k
Car: 1997 240sx SE
brokeAs240sx wrote:are you sure you tightened the coilover lock nuts enough? I had that problem at low speed turning/reversing and found out my lock nuts loosened themselves..
I checked it before and they looked tightened. I'll check again tomorrow.Hey QV! This is Leon, btw. Thank you for helping installing my brakes.
onosqv
Car: '92 240sx Vert
O, haha, so this is your SN.
Hmmmm, if it's not that those coilover nuts are too loose, then I'm not sure bcs I didn't remember your bushings being bad or anything like that. Guess we'll have to see next time your in the neighborhood .
Or maybe it is that dustshield that we bent out of the way, but that should make a relatively constant sound.
