crazyboy3012 »
https://forums.nicoclub.com/crazyboy3012-u72903.html
Tue Nov 25, 2014 6:28 pm
Hello,
The past few days I have been getting a clunking noise from the front right hand side every time i press the brake pedal. If i do a stop-go-stop-go i get cunk-clunk-clunk. Basically everytime i press the brake there is a noise.
In the recent past I have replaced the front lower control arm bushings (bushings only both sides), compression rod (entire rod both sides), links on both sides, tie rod outer ends on both sides. The rotors and brake pads (akebono) are fairly new as well.
About a month or so ago, i started getting the clicking noise everytime I press the brake. The noise seems to originate from the front right side.This was right after i got the compression rods installed. I took it back to the garage and the technician got the car up on the lift and thoroughly checked the suspension in my presence and everything seemed allright. He said it could be my front right calipers. I thought my front right calipers has failed and replaced it with a new one today and and guess what...the noise is still there. Its driving me nuts. I cannot imagine what could be causing this noise.
Can you guys think of anything else that could be causing this noise?
Appreciate your help !!!
