ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Sat Jun 05, 2004 6:06 am
Well, if you click on the link for the spacers for sale on Ebay, they have several pictures of the spacers installed. It's pretty self-explanatory if you look at the pictures. You just jack up the car, take off one subframe nut at a time(there are 4), put the slotted spacer on top of the subframe, and put the other spacer on the bottome of the subframe, put the nut back on and tighten it. You will actually have to loosen all the bolts a little to get the subframe to drop down enough to slide the top spacers in. Once you're done, just make sure the nuts are super tight, and drop the car back down.
Also, these can only be installed as a set. If you just installed one side, your rear alignment would be way off, and you would have serious handling issues.
