clunking noise from rear right break
xagna
After break gets heated up, whenever I apply break, I hear clunking noise at around 5 to 20 mph . Paticularly when I coast down hill.
When I check the break by its look, it looks o.k.
What could be the problem?
chmercer
is it possible that the inside pad might be worn down and you didnt notice? when a pad is down to the backing plate it will make wierd noises, but only at low speed.
xagna
Yes, I have to change pads and that's something new.
Thanks a lot.
