thelinja »
https://forums.nicoclub.com/thelinja-u2406.html
Thu Jan 22, 2004 4:48 pm
It's not the diff that's causing the clunk. It's the worn out bushings on the subframe. You have two options, you can either remove the whole subframe, burn the old bushings out and replace them with OEM bushings, or polyurethane bushings. Option two is to purchase subframe spacers and install them, it takes like 10 minutes, all you need is the spacers, some PB blaster and a cheater pipe. Do a search for subframe spacers, I think I remember someone selling them.
