Darian »
https://forums.nicoclub.com/darian-u5850.html
Mon Mar 17, 2003 3:16 am
Hello!
Any help with this problem would be very much appreciated (I'm not mechanically inclined, but will happily give any additional info that might be needed!)...
My car is the following:
1992 Nissan Sunny 1.6 SLX 4-door(European version of the Sentra, N14 model)119 000km (74,375 miles)5 gear manual-bought a month ago, newly serviced-1 previous owner (documented)-missing service history book-car/engine in good condition (looks well cared for)-passed standard annual MOT test (axle nut cover had minor crack, to be replaced, but not yet severe)
Problem:
A loud (single) "clunking" sound from below the car when making a right turn.
This is fairly consistent, but more predictable when going over any kind of bump (i.e. sidewalk crossing), regardless of how slow the car's moving. No problem on slight turns, when following normal curves on the roads - but the tighter the turn, the more predictable the noise.
After some good highway driving, I got the impression that the problem eased up a little (less likely to clunk) when returning to the city... but it didn't take long for the regularity of the noises to return!
At first, I suspected the CV joint, but the noise is not typical of the sound that has been described to me for this problem (and a fairly informed friend didn't think it sounded like the usual bad CV noise when he tested it). That is, the noise is not a "repeated" clicking or banging sound...
This sound is more of a single one-off "clunk" or "thud" sound - almost like something is loose and "banging" into something as the weight shifts to the right. Seems to come from below the driver or passenger feet (fairly central in the motor area). Even if I crawl the car at almost no speed, I still get this clunking sound!
The suspension while driving does not feel the best, but the MOT check didn't find anything wrong and seems ok when pushing down and testing it on the outside.
I'd really appreciate any thoughts about possible culprits here, as a trip to the garage could spell a blind investgation leading to hundreds or thousands of dollars in unnecessary repairs!
