PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Fri Mar 17, 2017 5:39 pm
Could be a U-joint going out, or a spring or motor mount or something. Tough to pinpoint really.
Does it happen if you are in neutral with the parking brake on and you just free rev the engine (nailing the throttle), or if you have the brakes on and hit the gas a bit?
If so, you can probably pop the hood and have someone look at the engine while you do it and see if it moves a lot, or try to look under the vehicle to see if something is moving/rocking.
