E7-S14 »
https://forums.nicoclub.com/e7-s14-u42538.html
Tue Mar 23, 2010 2:08 pm
hmm. well, others posted some good ideas that could be your problem.check your struts, upper mount could be loose, check for ANY LOOSE PARTS.
could also be your rear subframe, may seem like its not coming from rear, or even front subframe, make sure everything is BOLTED DOWN and tight.
check your motor mounts also. and your transmission mounts.
Hell i guess check every moving part in the front half of the car.
