Cjmartz2k »
https://forums.nicoclub.com/cjmartz2k-u65761.html
Fri Aug 27, 2010 9:07 pm
Much better info. Does the pedal give any resistance after you pull it up than push it again? Fist check the fluid level in the clutch master cylinder. Second, look for leaks around the slave. Third, bleed the crap out of it just for good measure. Look to see if the plunger is moving in and out of the slave. If no (or not enough) you are lucky and it's either a leak, back master cylinder, or bad slave. If that arm that the slave pushes on is floppy with no resistance, you'll likely be pulling the transmission. The revs can in no way effect the clutch pedal other than vibration which leads me to believe you have zero resistance from something in the system. For the BOV, check your vacuum lines. Has your idle been acting funny lately?
