You dont need to pull the motor to change the clutch, I installed mine with the motor in no problem.Sil240 wrote: Especially with the RB, since you have to pull the whole motor to change it.Do it once and do it right.]
were did you get it from?Kansei240sx wrote:296 forRB20DET Fidanza Flywheel
302 for DXD Kevlar Clutch and pressure plate, holds 480 ft lb's and 480+ with the cryo treatment, which i got.
I have the Top Hat mounts, you have to use a 3 foot 3/8" extension to get the top transmission bolts, and a ratcheting box wrench to get the ones against the firewall.Sil240 wrote:What mounts do you have?You must have the X-member
With Top Hat mounts you definetly cant
Really???I got the same setup.When it's time for me to change my clutch I'll fly you down to FL!!!rustbucket wrote:
