Hey guys.
So I just replaced the master cylinder, and the slave on my 89 coupe's clutch... I decided to make life easy, and bypassed the dampener like everyone seems to be doing. Bent the line no problem, everything hooked right up.... life looked grand.
NOW... I have no pressure in my pedal, and the master doesn't seem to be pumping.
My guess is, I should have bench bled the master cylinder before... but even with searching, I couldn't find out for certain if that was nessicary. Should I have done that? do I need to bleed the slave too?
Any input is appreciated, thanks
