mexillis »
https://forums.nicoclub.com/mexillis-u134831.html
Sun May 12, 2013 9:04 am
Go do an oil consumption test. Look for this same topic on here for some additional info. If you go to the dealer make sure to check your oil level prior to them checking, some dealers don't have integrity. You might want to check your oil level now to be sure you're not too low. You can also add a catch can to prevent blue smoke. Since you're under warranty I'd get the test done at the dealer first just incase you get a new motor.
mexillis on Sun May 12, 2013 10:58 am, edited 1 time in total.
