IvoryJ30t wrote:when you pull the head on an open deck motor, the cylinder liners are free standing. another words, the cylinders are attached to the bottom of the block, and the coolant circulates around the cylinder liners. the top of the liners are not attached to the deck of the block. they seal against the head/headgasket directly.
Is this why my friends Turbo B18C runs great with a radiator half the size of my stock radiator, and I still have cooling problems with my aluminum Koyo?
Seems taht would be the case if the coolant is able to completely surround the piston wall.. does it come down to open: cools better, closed: stronger ?
