Postby
GNR4ALL »
https://forums.nicoclub.com/gnr4all-u56272.htmlThu Dec 20, 2007 12:09 pm
So my car has been driving horribly lately. I tried a BG 44K session and now my mechanic says the catalytic converter is clogged thats why the performance is so bad. Is there any way to clean it? also if i need to replace it is this the part i need?
Postby
GNR4ALL »
https://forums.nicoclub.com/gnr4all-u56272.htmlThu Dec 20, 2007 12:45 pm
feels like the engine is choking. I always use 93 octane gas. the only thing i did recently was use the BG 44K. Is the link i put in my fist post the cats?
Postby
Q45tech »
https://forums.nicoclub.com/q45tech-u112.htmlFri Dec 21, 2007 4:28 am
What do the individual cat back pressure vs rpm vs load measurements show. PSI? Make a graph.
It sounds like you might not be using a certified trained on this model TECHNICAN?....................."my mechanic"
Careful non oem aftermarkets and high flows are designed to only last a few years at best thus low cost..............just to get thru the next emission test to sell a car.
CAT failure is very rare unless mods or ecu reflash, etc. Some states have longer cat warranty than oem warranty check your state epa if you are above 70k.
Postby
szh »
https://forums.nicoclub.com/szh-u149.htmlFri Dec 21, 2007 7:18 am
If the cats do need replacements, keep in mind that this item may be covered by a warranty item that is required by Federal and many state laws (for smog control issues). Please see the dealer and get a correct assessment for sure!
Postby
caug1 »
https://forums.nicoclub.com/caug1-u53800.htmlSat Dec 22, 2007 6:51 am
sounds like possibility of electrical problem?does this car has coil packs? or things that located right above the sparkplags? one of them not performing right?i forgot the name for them.
Postby
xerexabante »
https://forums.nicoclub.com/xerexabante-u48008.htmlSat Dec 22, 2007 2:20 pm
Why not try to unhook the cat then run to see if it runs better. should be only 4 bolts holding them. Or you can take it to the dealer for warranty Federal Emissions Warranty should be 8years/80k miles
