eazye2000 »
https://forums.nicoclub.com/eazye2000-u30064.html
Wed Feb 13, 2008 12:26 pm
Mods, feel free to title this accordingly.
So I got bored today, and read a little bit on Garrett's website. I found something that interested me, and sort of disagrees with with what we all know(think). This, I'm assuming, only applies to ball bearing turbo's. Or at least the turbo's with water cooling.So here's a cut and paste of what I read. Take a look at it, and tell me what you think.
***********************2. Water port orientation is critical for thermal siphoning (coolant flow through the center hsg when the engine is turned off) and turbocharger durability. Rotate the center housing so that the oil drain hole is not perfectly located at the 6 o'clock position. One water port should be slightly higher than the other. Connect the water line that is at a higher level in the engine cooling system to the higher port on the center housing. Then connect the remaining water line the lower port. Having the ports at a slightly different level will allow thermal siphoning and prevent air bubbles from getting trapped in the center housing cavities.***********************
.......discuss
