Clock/NAV issue
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
iamjeffb
Car: 2017 Nissan Armada
94 Nissan 300ZX 2+2
91 Nissan 300ZX TT
Hi everyone,
I'm a noob here and am asking for my mom.
2017 Armada:
Cannot use the NAV can't set a "home" it still shows for the previous owner.
Clock can't be set and it won't go past 2000 (guess the Y2K glitch DID happen) :lolling:
The XM works and I can save stations, I'm guessing the head unit needs a firmware and/or software upgrade?? I realize the maps are way out of date and could order a newer CD like most cars, but I don't really understand the non-functioning NAV and clock setting.
Any ideas, or help if it does need a firmware flash? Dealership was no help, they just said it prob. the head unit and they could order a new one but wants $$$$ for it.
Thanks,
JeffB
As for my Nissan loyalty - well, ex-owner - 94 - 300ZX 2+2 and 91 300ZX TT
http://twinturbo.net/ttnetrides/rides.aspx?user_id=67
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The head unit on a '17~'18 is actually the display, it's a Denso design that Nissan calls a DCU. They're hideously expensive, IIRC about $3K new. If you get a used one, make sure the part number AND the sound system on the donor (Bose/non-Bose) matches your mom's. We've seen terrible issues with reconfiguration if the audio config doesn't already match (it can actually disable the whole unit). That all said, check all the fuses both under the hood and in the cabin before condemning the DCU. Lack of battery backup can cause some pretty weird symptoms on those, especially if mom's ride is equipped with telematics.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
