clock bulbs and climate control bulbs
Domenico
Car: 2001 Infiniti qx4
Hey everyone. Does anyone know where I can get the 2 bulbs for my clock and the bulbs for climate control. I don't wanna pay so much from the dealer and I do not want leds. Thanks. Truck is 2001 qx4.
Domenico
nobody???
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Do you know the size/part numbers? Have you tried ebay?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Domenico
thank u.. radio shack had it for the clock but now i need for the climate control
Towncivilian
I believe the climate control also uses 12v microlamps. If not, they will be #74 bulbs more than likely. It would help if you could take a photo of the bulbs.
Domenico
this are the bulbs i need for my climate control..
Towncivilian
If it's not too much trouble, could I get a photo of the underside of the base? I'm wondering whether there are visible leads routed through the base. If so, it is a 12v microlamp; if not, the bulb just should pop out with a little force and it'd be a #74 bulb.
Domenico
Towncivilian wrote:If it's not too much trouble, could I get a photo of the underside of the base? I'm wondering whether there are visible leads routed through the base. If so, it is a 12v microlamp; if not, the bulb just should pop out with a little force and it'd be a #74 bulb.
Towncivilian
Yep, those would be 12v microlamps. You don't need to transfer the blue filter over, that just makes the light output a little warmer.
Domenico
Towncivilian wrote:Yep, those would be 12v microlamps. You don't need to transfer the blue filter over, that just makes the light output a little warmer.
but i cant pull the bulbs out.. on my clock light the bulbs pulled out and they were bigger but on these the bulbs are so small and i cant pull them out.. am i doing something wrong??
Towncivilian
Use a small flathead jeweler's screwdriver to pry the leads outward from the base, this will allow you to pull the bulb out and replace it.
Domenico
Oh ok. . Im missing one base.. do u know where I can get one
Towncivilian
Junkyard is your best bet.
