slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Tue Dec 27, 2005 3:45 pm
1992 Nissan 240sx, non-HICAS power steering, aftermarket inner tie rods, clinch, stake.
Just a couple quick question, as I've never had to replace inner tie rods before. The factory ones I pulled off had four staked sides, and a 'washer' that was clinched in two places corresponding to two grooves in the rack. That's fine, I understand how that helps keep the outer rod from spinning.
However on the aftermarket versions I've seen at all the local auto-part stores, it's like a flat washer, with two 'spikes' where the clinches would go. Below is a link to an example, and attaches is the factory version. How is the aftermarket version supposed to keep it from rotating?? Am I supposed to hammer the edges of the washer over the four sides of the tie rod?
Also is the Red LocTite too much for those inner threads, or something more suttle like the Blue LocTite?(removable w/hand tools, as opposed to heat).
Lastly, should there be *any* sign of P/S fluid on the inside of the boots? One 'rib' of the boot had a tiny puddle, but I don't know if it was from me messing with it, or the curb I hit. I'm afraid when I replace the boot(preventative maint, they aren't torn yet), I may not see immediate signs of fluid loss.
Thanks for reading,Jamie
Aftermarket:
Oem:
