elvis240sx »
https://forums.nicoclub.com/elvis240sx-u1160.html
Fri Jun 20, 2003 10:02 am
Yes i searched around but didnt find anything on how to fix my problem. Its a soch hatchback 240. When i bought my car about a year ago, the idle was really high, about 2k rpms. a few months ago i turned the idle down to like 900-1000k rpms. its ran really well for a while with no problems. Now, it seems to be acting funny. When i first start the car it will idle at like 1500rpms, then drop down to where i set the idle. after driving for a minute, if i stop at a redlight or stop sign, it will occasionally rise up to an idle of like 2100rpms and stay there. if i tap the gas, it will go back down, but sometimes climb up again. Im not sure what i should do in order to fix this.
not sure if this also has anything to do with the problem, but ill ad dit anyway. a few months ago, the car would bog out really bad if i stepped on it at all. but, if i just barely, and i mean barely feathered the gas, it would go without shaking or jerking, but of course really slowly. it was like i had to give ti just enough gas to take off without stalling. so, i took it in to one of the mechanics my dad works with, and he really couldnt find anything wrong with it, except for the timing being a little bit off, so he fixed that. 2 weeks later, it started happening again. this time, it was the alternator, so i put a new one on and the car seemed fine. now, the car will kind of bog out and seem gutless if i dont give it about half gas. at full throttle it seems choked out or weak, and it also feels that way at anything less than half throttle.
i have gone through almost all of the wiring connections and cleaned them with a wire brush and reconnected. i just replaced the 02 sensor 2 months ago, and fuel pump about 6 months ago.
BTW, when i first turned down the idle, im pretty sure i did it correctly, but maybe i didnt. there was a flathead screw on the passenger side of the plenum, so i turned it until the idle went down to where i wanted it to be. did i do this incorrectly?
if anyone can help, it is very much appreciated
