I've never heard of that, but off the cuff I'm betting the potentiometer behind the temperature dial is going bad. The same thing happened to the volume control on an old stereo receiver I used to have. It started out skipping around sometimes and then eventually would only lower the volume regardless of which way I turned it. You have this style of climate control, right?
If so you can try soldering a new potentiometer on, but you'll have to track down a replacement. Otherwise climate controls aren't too hard to come by on eBay.
If you have the style built into the navigation unit, I'm betting the climate control unit is bad. It's a black cigarette pack-sized unit that's mounted to the floor behind the navigation. Sadly they're much harder to come by
