Climate Control Unit
93240guy
Car: 93 240SX SE
On the Climate Control Unit everything works fine, except the lights. At night, when you turn on the lights, the climate control unit is suppose to be lit. Is there a way to replace the bulbs? or would i need a new unit.
This is on a 93 240sx SE
weg240sx
Car: 1995 240SX, 2008 Altima SE
I have a 1995 240 SX with the same problem, I have not found an answer yet. Everything works, you just can't see them at night.
2ndnissan
Car: 1990 240sx hatch
There's a little panel on top of the unit that flips up and has two bulbs inside. Little tiny things...dealers have them for around $9 apiece. There is also a write up on them in the tech section using bulbs from Radio shack.
93240guy
Car: 93 240SX SE
Thanks. I'm going go try that this weekend.
