Don't know if anyone knows the specs??bee900 wrote:Is this resistor different than the a/c amplifier?
You may well have 3 problems in that a bad fan motor usually causes failure in the Darlington transistor unit. If you don't want to repeat the labor, fix the motor while you are in there, or you will be back soon for another Darlington transistor bridge.elwesso wrote:You have 2 problems
the darlington resistor behind the glovebox is bad... Something like $50 to replace and like 30mins to do it...
Makes sense indeed... You know the last time I had that out, i took my blower motor apart and cleaned hte internals... Youd be amazed how much crap is inside the motor... Took the back plate off (2 screws), sprayed some brake cleaner, let it dry, then put a little WD40.. Let it dry completely for an hour or so, and it worked great.....maxnix wrote:You may well have 3 problems in that a bad fan motor usually causes failure in the Darlington transistor unit. If you don't wnat to repeat the labor, fix the motor while you are in there, or you will be back soon for another Darlington transistor bridge.
I did the same, but had to sand down the brushes, because the dust had wore grooves in them. Now it runs like new!elwesso wrote:
Anytime your in there I think its probably good maintenance and only takes about 10 mins to swap the blowers... I have 2 so i can swap em in ready to go.
Yes, we're freaks like that .elwesso wrote:Makes sense indeed... You know the last time I had that out, i took my blower motor apart and cleaned hte internals... Youd be amazed how much crap is inside the motor... Took the back plate off (2 screws), sprayed some brake cleaner, let it dry, then put a little WD40.. Let it dry completely for an hour or so, and it worked great.....
Anytime your in there i think its probably good maintenance and only takes about 10 mins to swap the blowers... I ahve 2 so i can swap em in ready to go.
