G35_Coupe »
https://forums.nicoclub.com/g35-coupe-u43740.html
Sat Sep 26, 2009 5:39 pm
'90 Q45
I can't get the climate control to turn on the A/C, or blow air through the air ducts.
Trying to fix a friends car.The climate control worked the way it should then it would work on and off. Then for the past year it hasn't worked at all.
When I started working on the car the climate control display didn't light up. The only thing that work was the defroster. I replace the climate control with a junk yard one. It does the same thing as the original one but this one the display works.
The blower motor works but I can't get it to blow through the vents.
