Climate Control stuck in ON position--01 PF LE
Adnan
Car: 2001 Pathfinder LE 4WD
Hey guys,I started my car a few days ago and instantly the a/c went off and now stuck at the highest fan speed.If I press the OFF button,it just recirculates the air through the lower feet level vents, if I press any other button it comes straight out from both upper and lower vents.I can adjust the temperature but no fan speed control at all.
Any suggestions?
thanks in advance
WPGQX4
Car: 1998 Qx4
Hey Adnan.
It's your Fan Control Amp. It's a common problem with Pathys a Q's with the auto climate control. Do a search in the forum for Fan Control Amp and there should be a thread on it. If you try and buy one new they are not cheap. I called some local auto wreckers here in canada and did some searching in the wrecked ones they had and finally found one. Cost me $10 cause they didn't know what it was worth new ($200). Good Luck
Adnan
Hey WPGQX4,
Thanks for the quick response,you just saved me lenghtly and potentially pricey diagnostic lol. am currently on the hunt for a PF for parts, but I might just the fan control amp new from the dealership,I don't know how long I can take the blowing air :LOL
I will search the forum for more info,thanks again!
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
Adnan wrote:Hey WPGQX4,
have you tried unplugging the unit untill you are able to get the fix?
