Q45tech wrote:Follow all the test proceedures in FSM to check sensor and acuator movement.Hopefully you don't have a failed [broken hinge] on the air mix door [locked in AC position or heater door. Did you recently buy car and not check for heater operation?Sometimes the doors break on 94-96 and this causes owners to sell in summer before winter? 10-14 hours of labor as the dash must be totally removed to swap the door.
Just speaking of the worst case situation.
10-14 hours to take off the dash???? No wonder the car doesn't squeak...it's put together like a vault.
So if you got it repaired at a dealer, you'd be paying about $100-110/hour....that's a lot of money for heat. Just bundle up and keep the butt warmers on high.
