Climate control problem on S14 Need help!!!!
an0uk1
Car: 95 Nissan 240sx / 92 Nissan 240sx coupe / 90 Mazda Miata
On my 95 SE the heater / AC blower only works on hi (number 4)The blower don't turn on 1, 2 or 3 but everything else works fine.Any suggestions or help??
ZeNkI S14
Car: 95 S14 (Redtop s13 sr20det built)
I have the problem to give me a holla if you find out and mine is the base model thanks.
MYK
Car: 1995 240SX SE, 1997 GTI-VR6
Mine had the same problem when I bought it. There is a resistor pack that screws into the bottom of the blower motor assembly under the passenger side dash. The "pack", actually a credit card looking thing with a big plug on the end is burned out. There are traces and resistor on the "pack", the resistors give you the slower speeds and on high it's straight through, which is why when they go out speed four still works. It's like 26 bucks at the dealer, cheaper at the online places. Very easy to change, also check that your blower motor doesn't maek any noise or sound like it's grinding or anything. If its not spinning smoothly that can increase resistance and continue to burn out the resistor packs
97ka-t
Car: 1996 Nissan Maxima
1998 Nissan Altima
Oh wow, I just posted on the exact same problem! Thanks for the help! ('97 240)
