[stock] climate control.. how do I fix it?
fuzion
Car: Cars.. Web/graphic design.. Yuppp
Okkkk... my friggin climate control is uber retarded
It doesn't change. Sometimes it will; sometimes it won't, like when I need it
For instance:
One night it was cold outside [imagine that!] and my window was fogging up.. so I switched it to defrost, no problem. Next day when it's really hot and my ice cold a/c would feel great blowing air at my face, it decides to get stuck on the defrost vents. So, the button is set to the front vents, but it's still coming out of the defrost vent. Later that night, get in my car, again it's cold and the windows will fog up, it decides to switch - to the front vents because I never took it off that setting. YAY.
I was playing with it the other day.. it was stuck in defrost 'mode' again, I set it to the front vents and then started moving the little slider/plastic parts down there that direct air flow and it moved into place. Has anyone else had this problem? Is it just getting stuck? Do you think I should grease them up?
Just wondering... it's really annoying, thx :)
