JodieRob »
https://forums.nicoclub.com/jodierob-u271949.html
Wed Feb 22, 2017 4:50 am
DIY FX Heater & Air Condition > 2003-2012 Infiniti FX35 - FX45 - FX50 A/C Self Diagnostic Procedure
Models:
* 2003 Infiniti FX35 - FX45
* 2004 Infiniti FX35 - FX45
* 2005 Infiniti FX35 - FX45
* 2006 Infiniti FX35 - FX45
* 2007 Infiniti FX35 - FX45
* 2008 Infiniti FX35 - FX45
* 2009 Infiniti FX35 - FX50
* 2010 Infiniti FX35 - FX50
* 2011 Infiniti FX35 - FX50
* 2012 Infiniti FX35 - FX50
Instructions
* Step 1SET IN SELF-DIAGNOSIS MODE
* aTurn ignition switch ON.
* bSet in self-diagnosis mode as follows. Within 10 seconds after starting engine (ignition switch is turned ON.), press OFF switch for at least 5 seconds.
* Step 2SENSOR CIRCUITS ARE CHECKED FOR OPEN OR SHORT CIRCUIT
* Malfunctioning Sensor
* 21 / -21Ambient sensor
* 22 / -22In-vehicle sensor
* 24 / -24Intake sensor
* 25 / -25Sunload sensor (Ignore this code)
* 26 / -26Air mix door motor PBR (Driver side)
* 27 / -27Air mix door motor PBR (Passenger side)
* Step 3MODE DOOR AND INTAKE DOOR POSITIONS ARE CHECKED
* aPress temperature (UP) switch (driver side).
* Malfunctioning Actuator
* 31VENT
* 32B/L
* 33B/L
* 34FOOT
* 35D/F
* 36DEF
* 37FRE
* 3820% FRE
* 39REC
* Step 4OPERATION OF EACH DOOR MOTOR IS CHECKED
* bPress (DEF) switch. Code No. of each door motor test is indicated on the display.
* Step 5TEMPERATURE OF EACH SENSOR IS CHECKED
* bCode No. 51 appears on the display.
* cPress (DEF) switch one time. Temperature detected by ambient sensor is indicated on the display.
* Note:
* If temperature shown on display greatly differs from actual temperature, check sensor circuit first, then inspect sensor.
* cPress (DEF) switch a second time. Temperature detected by invehicle sensor is indicated on the display.
* Note:
* cPress (DEF) switch a third time. Temperature detected by intake sensor is indicated on the display.
* Note:
