Scott-o »
https://forums.nicoclub.com/scott-o-u261088.html
Sun Jul 17, 2016 8:49 am
Hello -
A new problem on our QX4 cropped up. The fan for the climate control system seems to be on "high" all the time, regardless of how you change the temp setting, or try to change the fan speed setting, manually.
When the system is turned "off", the fan still blows - it blows out the floor vents at that point.
The AC blows cold, seems to respond to what the temp control is set at. I think it is just the fan speed that is the problem.
The Infiniti dealer just did the pass side airbag recall - the system was working fine prior to that. Ugh. Probably not related, but still, don't you love that?
Scott
