Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Dec 18, 2002 5:16 pm
-26 means PBR is shorted refers to air mix door [told you to look there shop manual has hundreds of pages describing testing].....sensor tells the controller the position of door.......the door is commanded to go to open, anywhere in between, and closed......the sensor reports where it actually is! Shorted symbol may actually mean the door is not exactly where the controller commanded it to be stuck/broken/slippped.
HVAC diagnosis is a job for dealers as the system is difficult to get at and many oppurtunities to disconnect [make intermittent]other vital systems when you have dash apart!
When we have problems we first substitute a know good controller before ripping into dash!
If it was a Lexus I would say to look for Rats living inside HVAC, on a Q they live under the engine plenum [9 cases so far this year]...........never keep dog/cat food in Garage!
They use the plastic as a tooth brush/dental floss.
