dudealex1 »
https://forums.nicoclub.com/dudealex1-u57844.html
Thu Feb 22, 2007 6:18 pm
I removed my climate control unit with the rest of my center console a while ago to install an aftermarket HU. Ever since, none of the buttons on the climate control unit illuminate, although the display does. I've had it apart several times since then and I'm sure I didn't miss a wire. Also, I'm sure that there are too many bulbs behind those buttons to burn out simultaneously. My best guess is that unhooking the radio disabled those lights somehow? Is there any way to bypass that prob?
Anyway, this is my first post, so thanks ALOT!
Edit: I did check the wiring and it is in tight, so I know that isn't the problem. I'm guessing it has something to do with not having the radio, and I'm hoping I just have to jump 2 pins on the wiring to make it work... or something. Also, the defrost and hazard don't illuminate either (I'm not sure if they're supposed to) although the indicator that tells if they're on or not works.
Modified by dudealex1 at 8:42 PM 2/24/2007
