clicking when turning the key
coupelove864
I recently bought a 89 s13 hatch, it had no motor and but already had the dash plug wired for the de and everything ready for a dual cam. So i dropped the motor hooked everything up and when i turn the key, the only thing im getting is just a clicking sound. It only clicks once when i turn the key. Has anyone else had this problem, or any ideas as to why this is happening? Thanks
r3v_v3ng3
Car: 91 fastback ka-t
starter maybe?
coupelove864
na its not the starter iv already checked that out, and all my grounds its a clicking coming from the relay but i replaced and still i am getting the same thing
vancouverbc
Car: 1991 240sx
coupelove864 wrote:I recently bought a 89 s13 hatch, it had no motor and but already had the dash plug wired for the de and everything ready for a dual cam. So i dropped the motor hooked everything up and when i turn the key, the only thing im getting is just a clicking sound. It only clicks once when i turn the key. Has anyone else had this problem, or any ideas as to why this is happening? Thanks
every person in the forum has had this problem.
see the tutorial on starter trouble shooting
ShaunakaRichard
Car: 92' 240sx sr20det Redtop
The clicking is the starter solenoid, if its doing that 99.9% of the time the battery isn't providing enough power. If you know for a fact the battery is fine then there must be some unseen resitance, check your wires to it. Its possible the solenoid is bad but far more likely the starter just isn't getting enough juice.
