Ignoble »
https://forums.nicoclub.com/ignoble-u119254.html
Thu Feb 26, 2009 10:57 pm
Sounds like exhaust leak? Does the problem persist after the car heats up? Check where the manifold bolts up to the block I've noticed most Ka's ive had are usually missing some of these bolts causing exhaust leaks. If the sounds stop after the engine warms up probably cause its hot enough that the metal expands and closes the leak. That's my best guess. If not might be ticking lifters or sticky valves. Various things, but should just go around checking everything is bolted on oil level is good and clean and all that stuff.
