Clicking/Tapping Noise In Front Of Head
sworxx
Car: 95 Nissan 240SX S14
Recently I began to hear a tapping/clicking noise in the front of the head on my 95 240SX. I had a mechanic listen to it, but he is not a Nissan Specialist. He thinks it is a timing chain tensioner and nothing truly serious, "Nissan motors are noisy," he said. I intend to take it to Nissan mechanic on Monday, but thought someone else might have an idea. The noise does not appear right away. Once the car runs for about 5 minutes, the noise apears. Revving the engine a little, the noise continues, but doesn't seem to really get louder. Prior to this I had done a coolant flush and refill, following the instructions in the manual and FAQ board. Heat works, car doesn't appear to be overheating. Don't believe I overheated the car. The noise seems to be towards the front of the head. Any ideas? Thanks.
DOOM240sx
Car: 93 Hatch too Custom 4 u
Sounds like the the timing chain tensioner or guard...i had the same problem with mine..they removed it and it seems fine now...also check your water pump if u havent replaced it ina while...mine made a similer noise when it was goin bad.
DOOM
candela
tensioner or water pump exactly...
and yes "nissan motors are noisy" :p
BadMojo
Car: 2007 Mazdaspeed 3
candela wrote:tensioner or water pump exactly...
Is it a hollow tapping sound? I had an arrythmic tapping sound from the front of the valve cover that turned out to be a bad upper tensioner. Removed both *upper* guides and replaced a tensioner. That really quieted down the KA. And, yeah, it's not a particularly quiet engine.
sworxx
Until this, it was pretty quiet for a track car. I took it to Nissan and it is indeed the timing chain guide. The fix is to remove them, but they said not to bother. Better to leave them in place.
Willkun
Car: my new 240 and my GF
I had a similar problem with mine but when I checked it I noticed the guard was actually broken off from the wear of the chain hitting it. A friend of mine was able to weld and fix the guard, and no real damage done. I just wanted to add that if it's making sounds, from hitting it. It's very possible it could be broken in due time.
sworxx
It's not terribly loud, certainly doesn't seem to be lashing around in there. Thanks for the heads up.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Well before you do anything expensive take off your valve cover and remove that guard over the chain. See if the noise goes away.
