clicking sound from engine?
Discuss topics related to the VQ series engine.
vliou
Hello,
Hopefully someone can tell me whether or not the clicking sound I hear from the middle of my engine bay is normal? It's a tick-tick-tick-tick sound...in a rhythm. As I rev the engine, the ticking gets louder?
Thanks!
VQ35-Fiero
Car: 87 Pontiac Fiero GT (VQ35det)
Well its heard to tell with the tick-tick-tick-tick description you give..... This describes a lit of things!!! Most likely it your injectors. other thin that it might be a lifter or valve tap. there's my guess.
Injectors Tick tick tick.
Valve and lifters Tap tap tap.
wrist pins Tang tang tang.
And rod bearings Clack Clack Clack..... TRH.
450sxtc
Car: 95 pearl vq'd s14 SE, 96 red s14 SE, 88 Rx-7 GXL, 90 GXL, 03 G35 Sedan, parting 91 q45
listen with a stethescope touching the top of your vtc solenoids. be sure and check both banks. If you hear the noise loudest at either of these then it's most likely a cam chain tensioner that has worn down to the metal. We've seen a few of these come through the dealer doing this. the fix is a chain and tensioner.
MaXimaSE
Car: 1998 Nissan Maxima SE
Im getting a rapid "tick tick tick" from the middle of my engine as well. I'll have the hood up listening to it idle, and Ill hear it.. pull up on the throttle and the roar from the engine mutes it, but soon as Its back at a idle you can hear the "tick tick tick"
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
