Clicking Noise When Turn on Heat (It's Not Blower Motor)
mppp78
Car: 2004 Nissan Pathfinder LE
2004 Nissan Pathfinder.
When I turn on heat there's a clicking noise and it's not the blower motor which I originally thought it may be as I replaced it and same noise persists. Also, while in there I replaced cabin air filters and resistor.
Thoughts?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
It's probably one of the HVAC door actuators. They often lose track of their home position when they go bad. That causes them to sit there bottoming the door for awhile after powerup, clicking because the door is already at the limit and won't move any further.
mppp78
VStar650CL wrote:
Sat Nov 29, 2025 6:58 pm
So far I'm finding mode or blend door actuator in my searches that appears to be on the drivers side? Is this correct? (link below for possible part if correct although I certainly won't be looking to spend this much on it)
https://www.z1offroad.com/heater-and-bl ... Cb1bO5u2e0
Thank you
VStar650CL
Technical Expert
Depends if you have an Auto setup or Manual. Manual only has an Intake actuator, that's up behind the glove box on both types. The Auto setup has Mix and Mode in addition, IIRC Mode is on the left side of the HVAC box and Mix is underneath it at the base of the center console. Any of the three can be responsible for a click-click-click.
