Clicking noise when shifting into reverse + play in RF wheel
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
For some time now every time I shift it Reverse and sometimes Drive I get a clicking noise from the back of the car. What could be causing this?
Also when I checked for a bad ball joint on the RF wheel I found there was play in the wheel. It is not the ball joint (not checked with a dial gauge). The whole upper link and king pin shake when shaking the wheel. But when I put a pry bar to pry up on the ball joint there is no movement. What could be the issue here?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Clicking sound could be as simple as the brake pads moving in the calipers or the calipers moving on the pins.
As far as the play it kinda sounds like it could be in the upper link or kingpin. Can you tell where it's "pivoting"?
